more active handling problems, errr
ME =
HERE TAKE SOME MORE MONEY.
= dealer
tcs c1276h c1287h c1288h I see that one of those is improper rate for the sps but the others umn whats up
more found that they didnt tell me about? what are they
u1016h
u1064h
u1040h
u1088h
u1176h
u1016h
u1064h
u1040h
u1088h
u1176h
1287 is a steering sensor rate malfunction. The EBTCM senses a steer rate (how fast the steering wheel is being turned) that exceeds the limits set by the EBTCM. There are 4 signals involved. Phase A, Phase B, Analog voltage and the index pulse. Again dirty contacts and loose connections can cause a problem. Phase A and Phase B are used by the EBTCM to tell which direction the driver is trying to steer during an ABS event and are also used to determine the rate. The rate value is used to control the amount of boost from the Magnasteer steering rack.
A diagnostic the tech can do with the tech 2 is monitor the Phase A and Phase B signals while turning the steering wheel. If they do not change uniformly the diagnostic procedure says to replace the steering wheel position sensor. Other branches in the diagnostic procedure lead to EBTCM replacement.
1288 steering sensor circuit malfunction. This code is set when the analog voltage mentioned above falls out of the .2 to 4.8 V range. It can indicate an open or short of the signal. Procedures lead to open circuits or in some cases replacement of the EBTCM.
All 3 are history codes so the car should have been working fine when you took the codes.
You should get a Service Manual so you can understand what is happening when these codes are set. Just reading the code doesn't provide enough info to make a repair.
The wheel speed sensor is part of the wheel bearing and you can get cheaper ones from the aftermarket. The steering wheel sensor failure usually shows up as a Service Vehicle Soon message. The U codes aren't particularly meaningful. They represent State of Health messages the various modules send each other on a regular basis. Like any networked system sometimes a message is missed but is OK on the next try. The results are those codes and the fact that they are all history codes indicates things are alright now.
Bill
