Front height question
Old Jun 11, 2005 | 11:06 PM
c5man99's Avatar
c5man99
Default Front height question
I have a 99 coupe, 422c.i., set up for drag racing and slill can be driven as a daily driver. Question: my new motor setup with the extra weight, has caused difficulty in aligning the front end. Do I need to use a heaver front spring( maybe a T1) or maybe one from Vette brakes? I am adjusted up as far as it will go, still can't set to spec's. Any reccomendations will be greatly appreciated.
Old Jun 12, 2005 | 06:48 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
VBP will make you what ever you want in springs. I have some heavier road race springs F?S but probably not good for Drag racing. They won't let the weight transfer as good. Call VBP and ask for Gary G. mention my name please.
Old Jun 13, 2005 | 08:01 PM
c5man99's Avatar
c5man99
Thanks, John................I will call and see what they reccomend. I may be stuck having to use a heaver uni-spring to handle the extra weight.
To Front height question
