Trouble At the Gas Pump
Old Jun 12, 2005 | 01:39 AM
LIGHTNING's Avatar
LIGHTNING
Default Trouble At the Gas Pump
Pulled into Amoco station to fill up the other day...needed about 12-13 gallons. Pump clicked off after about 5 gallons. I started it again...went for another 3 gallons & clicked off again. Hose was connected properly. First time this happened. Wonder if the flow from gas pump was too fast??
Old Jun 12, 2005 | 02:25 AM
Shylor's Avatar
Shylor
This has happened to me once on my 2003. Try pumping slower or after pumping some fuel in waiting a few seconds. Most likely air in the system causing it. There is a TSB to replace the fuel filler neck, to one that is less angled. I decided against having a dealership screw with my car over this.
Old Jun 12, 2005 | 11:03 AM
b98's Avatar
b98
the pump is stopping to let you earn more money to pay the rip off prices they charge us.
Old Jun 12, 2005 | 11:17 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Vapor lock. Sounds like the autoshut off on the pump is broken. Did you go to another pump?
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Maybe its actually full...
To Trouble At the Gas Pump
