blackwing maintenance
Old Jun 13, 2005 | 01:05 PM
jjsgroi's Avatar
jjsgroi
Default blackwing maintenance
bought a used blackwing from aforum member ,no problems but not able to contact him, need to know what the plastic container on the side is for?? and how and is there a service kit to clean and i guess oil thanks jim
Old Jun 13, 2005 | 02:37 PM
rrross's Avatar
rrross
Yes there is a service kit, I bought mine from Midamerica. the plastic container you described, is it the indicator that tells you to clean the filter you are talking about?
Old Jun 13, 2005 | 04:01 PM
Special K's Avatar
Special K
You can also use the K&N recharge kit. There is no plastic container on the side. There is an air indicator on the top on the drivers side.
Old Jun 13, 2005 | 07:54 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
No flames but I have heard not to mix the K&N and Blackwing cleaner and oil. Something about K&N being cotton-based and Blackwing being synthetic-based.
Also, don't over-oil the element!! The excess oil can build up on the MAF wires and cause trouble.
For what it's worth....
Old Jun 13, 2005 | 09:10 PM
Special K's Avatar
Special K
I've heard the same thing. Also heard that's BS. I have a Blackwing and a k&N recharge kit. No problems.
Old Jun 14, 2005 | 12:30 PM
C5-BRUCE's Avatar
C5-BRUCE
...Also, don't over-oil the element!! The excess oil can build up on the MAF wires and cause trouble.
Absolutely correct Below is an archived email.
I have been doing a lot of mods to my car, and in the process I have
had to "scan" the engine with a program on my laptop called "Ease". We were
really getting a lot of problems with the performance and tune, but the car
"seemed" to run fine. It turns out, my BlackWing filter got oil on my MAF
sensor, and resulted in the sensor not reporting all the air going through.
The result was more oxygen being delivered than PCM knew about, and then the
O2 sensors were running very lean. This condition then results in the PCM
retarding the spark/timing, thus harming performance. The "oily" MAF was
solved easily by taking the MAF sensor off the intake, and then spraying an
electronics cleaner available from Radio Shack on it. I did it a second
time to be sure. Shake excess cleaner out and let the MAF sensor dry well,
then reassemble your intake. The car was running much better after that,
and we were able to be a better custom tune.
To blackwing maintenance
