correct voltage #s
Old Jun 13, 2005 | 04:56 PM
jheart11's Avatar
jheart11
Default correct voltage #s
hi my DIC shows 12.3 to 12.9 volts with eng running is this correct? what #s should thay be thanks
Old Jun 13, 2005 | 05:12 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Mine typically shows around 13.8 - 14.0 with the engine running.
Old Jun 13, 2005 | 05:28 PM
jheart11's Avatar
jheart11
does that mean my battery or alt is bad? thanks
Old Jun 13, 2005 | 06:13 PM
thisMSGgood4me
I would first get the battery tested. If it fails or is weak, put a new battery in and see if that solves the low reading on your DIC. If the old battery is okay or you put a new battery in and still get a low reading, have the alternator checked out. On other words, go for the easier solution first, then move on to the more expensive one next. Besides, batteries fail much more often than alternators.
To correct voltage #s
