Zip-Corvette Lowering Kit???
Old Jun 14, 2005 | 02:14 AM
1-BAD-C5's Avatar
1-BAD-C5
Default Zip-Corvette Lowering Kit???
I ordered this kit the other day and am goign to lower my vette probably this weekend,... when the car is lowered keep in mind im cutting the bushings, should i cut the black air damn that sits directly under the radiator and if so how much should i cut off, i dont want it to drag on the ground.
Old Jun 14, 2005 | 08:19 AM
leaftye's Avatar
leaftye
It's made to drag, why not let it do it's job? It serves as a cautionary device to let you know you're getting close to having hard parts hit the ground, and by cutting it, you're putting your car at greater risk of tapping the ground. If you already have the A&A kit, then it's not really a big deal. I recommend you keep the air dam to retain the cooling and aerodynamic advantages, and get the full A&A kit for the extra protection.
