Help with some codes
Old Jun 14, 2005 | 09:14 PM
4deatr's Avatar
4deatr
Default Help with some codes
Can anyone help me on some codes I pulled off my 01 vert. What system the codes are in.
60IPC
A0LDCM
A1RDCM
A6SCM
I had one in the HVAC but I know that one
Old Jun 14, 2005 | 09:24 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
60IPC
A0LDCM
A1RDCM
A6SCM
Left door control module
right door control module
seat control module
Sound's like the seat harness is acting up. Where did you get theese codes? Those are not DIC codes.
Old Jun 14, 2005 | 10:01 PM
4deatr's Avatar
4deatr
I did pull them from the DIC.
Old Jun 14, 2005 | 10:15 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
acording to the gm esi manual no results found
File Type: doc
Old Jun 14, 2005 | 10:27 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
the codes are usally one letter then 4 numbers and the letter H=history or C=current
To Help with some codes
