Mildew in my Rag Top
Old Jun 14, 2005 | 11:44 PM
dabsplaza's Avatar
dabsplaza
Default Mildew in my Rag Top
Just bought a 98 roadster with an Oak color convertible top. The top has a significant amount of black mildew spots ingrained in the material. Tryed to get it out with typical over the counter top cleaners with no success. Any suggestions???? Hate to spring for $1,200 bucks for new top. Thx. for the help.....
AT
Old Jun 15, 2005 | 09:58 AM
cenzo's Avatar
cenzo
AT, if there's a boating supply store near you like Boater's World etc. they sell a spray mildew remover that works well. Unfortunately I can't remember it's name at the moment. If you find it, test for color fastness first in some inconspicuous place on the top.
It's called STARBRIGHT MILDEW REMOVER.
Old Jun 15, 2005 | 10:13 PM
dabsplaza's Avatar
dabsplaza
Thanks for the advice Vince. I'll try to locate that product and post my results.......
AT
Old Jun 15, 2005 | 10:58 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
My sister has a newer mustang GT and the tan top mildewed. She had someone that was a detailer do it. He used a spray, I don't remember what it was though.. supposed to be just for these kind of tops.
BTW.. that starbrite marine stuff is basically bleach. It contains chlorine. Be careful with it. It will clean mildew, but it's harsh on fabrics/stitching. I would dilute it if you use it and keep it off the paint as much as possible. But it will clean it.
Old Jun 16, 2005 | 02:24 PM
newgene's Avatar
newgene
I actually used very diluted bleach, and it worked very well. Of course, with bleach you have to watch how strong. I did it a while back, and I was really worried that I went too strong. Apparently not, and the top looked great. It works great, but just be careful with it.
Old Jun 16, 2005 | 03:38 PM
Laguna Blu's Avatar
Laguna Blu
Are you sure that it is mildew and not wear spots? The oak top tends to show wear (especially the pre-2001 edition) resembling black dirt or mildew. No matter how much scrubbing you do the wear marks will only worsen.
Old Jun 16, 2005 | 06:58 PM
RoHo's Avatar
RoHo
Give RAGG TOPP a call, they make a cleaner and protectant kit for rag tops that been endorsed by Haartz, the MSL tops. My partner uses it on his Hot Rod and the top always looks new.
800-377-4700 or www.wolfsteins.com for a web site.
Old Jun 16, 2005 | 09:37 PM
dabsplaza's Avatar
dabsplaza
Thanks for the info guys..... It's not wear spots. It's a low mileage car and the top is in great shape except for the mildew.
I already tried the Ragg Topp product. Great stuff but it didn't touch the mildew.
As a last resort, I might try the diluted bleach. If it screws up the top (ie takes the color out) then I will spring for a new top My biggest concern with using something like bleach or another industrial strenght cleaner is damaging my paint. That would be a double whammy.
PS How diluted should the bleach be (ie one part bleach to four parts water????)
Thanks again....
Old Jun 17, 2005 | 10:51 AM
newgene's Avatar
newgene
I actually did it somewhere around that, or actually stronger. I probably went too strong, but for one time, it didn't do any damage. I think at around 20% bleach you would be fine to test it out. I also didn't leave it sit longer than the time to clean it. I sprayed it off immediately afterwards to neutralize the caustic effects. Again, it helped, but I don't think it's something you would want to ever week. In my case it was mildew, and bleach seems to work in almost every application for that. It sounds like you'd be sensible with it, and that's probably the most important. I would give it a shot to try it. If you dilute it enough, you shouldn't hurt anything at all.
Old Jun 17, 2005 | 11:10 AM
bierbelly's Avatar
bierbelly
There is a product at your grocery store called "Chlorox Cleanup" which ought to do the trick. It works great in the shower and it already has soap (surfactants) in it. Spray it on, brush it in and hose it off. Again, I wouldn't leave it on too long. I'd think that two short applications would be better than one long soak.
To Mildew in my Rag Top
