Synchromesh ATF
Old Jun 15, 2005 | 11:02 PM
caster5303's Avatar
caster5303
Default Synchromesh ATF
Want to change the oil in my 6sp manual trans, I have a 2000 coupe. The tech "sticky" recommends staying away from synthetics (like Redline MTL) for 2000 and older C5's. Anyway, dealer wants $16.60 per quart for the Synchromesh. Anyplace to get it cheaper?? Need 4 quarts to do the job.
Old Jun 15, 2005 | 11:06 PM
chriswtx's Avatar
chriswtx
Roal purple Syncromax for $7.98 a quart. Got it at Oreiliy's auto parts...
Old Jun 15, 2005 | 11:07 PM
99 The Hard Way's Avatar
99 The Hard Way
I have used synchromesh in all 3 of my C5's and never had a problem. Definately improved feel and shifting quality. Not sure about where to get it cheaper. Scott
Old Jun 15, 2005 | 11:13 PM
chriswtx's Avatar
chriswtx
Also Autozone has Penzoil synchromesh(not synthetic) for around $7. Thats what I used in my ZF6 in my 91 vette
Old Jun 15, 2005 | 11:34 PM
chriswtx's Avatar
chriswtx
The Sticky states that the Roalpurple scyromax is safe to use.
Manual transmissions -- Replacing the transmission fluid often helps shifting. Early transmissions have paper blocker ring that require Dexron III compatible (usually organic) fluid because some synthetics will destroy the paper blocker rings and subsequently the transmission. Later transmissions, and all rebuilt transmissions, have Kevlar/carbon fiber parts that allow the use of synthetic fluids. I believe the 98-00 transmissions have the paper blocker rings. The safe transmission fluids seem to be: GM Synchromesh PN #12345349, Honda ATF-Z1, Royal Purple Synchromax, Amsoil ATF, O’Reilly Dexron III ATF.
Old Jun 16, 2005 | 08:13 AM
Mr. Jones's Avatar
Mr. Jones
steeda.com has synchromesh for $9.42ea.
don't tell anyone I posted this
Old Jun 16, 2005 | 10:13 AM
ericdwong's Avatar
ericdwong
I use SynchroMax in my 98. So far so good......I got mine from Jegs but u gotta pay shipping.
Old Jun 18, 2005 | 02:23 AM
coast7's Avatar
coast7
Is that sticky still valid? What is its source? I am running Mobil 1 Synthetic ATF with very satisfactory results.
I read this: Mobil 1 Synthetic Automatic Transmission Fluid
Outperforms conventional ATF and meets General Motors' Dexron® III and Ford's Mercon® requirements. Fully synthetic formula that provides outstanding resistance to oil breakdown and deposits under severe duty and high temperatures.
Helps extend transmission life through excellent durability and protection.
For many GM, Ford and import vehicles. Approved for use in vehicles specifying: Dexron III, Dexron IIIE, Dexron
Now approved for H specification, the latest GM Dexron III performance level.
Old Jun 18, 2005 | 11:01 AM
chriswtx's Avatar
chriswtx
I put Mobil 1 Synthetic Automatic Transmission Fluid. I didn't quiet like the way the shifts felt so I drained 1 quart of fluid and added 1 quart of Roalpurple syncromax and the shifts are much smoother
To Synchromesh ATF
