Strange loud whine
Car year: 2000
Miles: 84,000
Tranny: M6
Well I had my car dynoed at A&A party
. So later on that day when driving at night I get this loud noise coming from the front of the car, at least it sounds from the front.
It happens when the engine is accelarating. It does not happen in 1st gear or 2nd gear. The noise happens when I am in 3rd, 4th, 5th and 6th. This only happens when I apply the gas. If I remove my foot off the gas the noise goes away.
At first I thought bad tire noise, nope!! Would happen if I took my foot off the gas.
Could it be tranny related. Differential issue.
Could doing the dyno screw something up?
. I checked under the hood and everything looks okay. I have no leaks anywhere. When idleing no weird noise. Just when I apply the gas pedal.
Please help guys.
Thanks.
P.S should mention the noise is not the marble noise, sounds like a high pitch of some kind.
I tried that when I am doing any speed between 30 mph and 70 mph, I get the whine. Once I put the clutch in and keep the rpm the same the noise is gone.
ok...well heres a TTT for ya in case you stil need input
I've learned to ignore mine...pretty much anyway.
I changed the differential fluid and oil change yesterday and it sounds the same. I thought maybe by checking the differential fluid for metal pieces it would point me to something, but no luck which is good.
Now I will check the throttle and everything up to the manifold. You could be on to something.
I will do a search.
Thanks.
I will do a search.
Thanks.
So it has to be something.
Thanks for the input.
