Valet install
Old Jun 17, 2005 | 11:19 PM
Batmbl's Avatar
Batmbl
Default Valet install
Does installation of the window valet require removal of the lower panel under the steering wheel?
Old Jun 17, 2005 | 11:42 PM
C5 RACNG's Avatar
C5 RACNG
NO, just get under there and plug it in
Old Jun 18, 2005 | 01:19 AM
rockrz's Avatar
rockrz
I wish all mods were this easy. Once you plug it in and set it up, you'll never have to think about it again.
Old Jun 18, 2005 | 06:48 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Negative, easiest mod ever. Just follow the steering column down until you find the opening. Just plug the valet into the exposed OBDII port. Might take you 5 seconds the first time and then two each time after. The programming will take some time just cycling thru the options on the DIC but the plug in is a piece of cake.
Paul
Old Jun 18, 2005 | 07:18 AM
No it doesn't. Very easy install to do.
Old Jun 18, 2005 | 01:03 PM
white90conv's Avatar
white90conv
Since it is so easy to install, it is also easy to steal. I agree with others who suggest you unplug it when you leave the car in for service.
Old Jun 23, 2005 | 09:19 PM
Batmbl's Avatar
Batmbl
Thanks for the replies. Don't know how I managed w/o this mod before!
To Valet install
By Michael S. Palmer | 2026-06-03 09:39:05
