Reuse Cometic head gasket?
Old Jun 18, 2005 | 11:31 PM
98Pace6sp's Avatar
98Pace6sp
Default Reuse Cometic head gasket?
Long story short I installed new heads, with Cometic head gaskets. Started car for about 5mins tops, but had a dead cylinder. Checked and no compression. Thought somehow I'd bent a valve during install. Removed head and everything looks great. No marks in piston or on valve and valve looks closed. I now believe I might have messed up the Harland Sharp rocker install on that cylinder. So my question is can I reuse the Cometic head gasket, or do I need order a new one? As per ARP head studs instructions I used I only torqued head down to 65lbs.
Thank you for your inputs,
Kevin
Old Jun 19, 2005 | 01:01 AM
2mcvett's Avatar
2mcvett
I reused mine. New motor had 2000 miles. Had nitrous backfire and blew the back out of the Fast 90 intake. A piece of the intake got in the cylinder so I had to pull the heads and check. Cleaned the gaskets with brake clean, painted them with cheap semi gloss black paint,( light coat) reinstalled them no problem. This was per Allen Futral.
Old Jun 19, 2005 | 03:42 AM
ScreaminDemon's Avatar
ScreaminDemon
I looked into this last week. I thought I may have to do the same after a water jacket leak on my 427 so I call Dave at Catek. He said once the gasket is compressed they should not be reused. I was also told by Darton that alot of tuners use the copper gasket sealant on these first, but Cartek never has. These gaskets are $200 so I don't blame you if you get away with it. My leak sealed itself after the first heatcycle, so lucky me! And 65/ftpds on the ARP studs is when you are using the moly lube, going more with the lube you could actually warp the head. Alot of tuners just use oil, and I'm sure the tq would be more.
Old Jun 19, 2005 | 06:29 AM
Z06 Steve's Avatar
Z06 Steve
I have a set of them and just finished a head/cam install.I would prolly dump them and get a set of mr gaskets $35 each that are getting good results.
Old Jun 19, 2005 | 08:05 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
I say no IMHO since it already has the imprint of the first install...
Old Jun 19, 2005 | 08:24 AM
rwj383's Avatar
rwj383
What?? you're thinking of composite gaskets.
Yes, you can reuse an MLS multiple times, with confidence, as long as you clean it real good, and check that it is not damaged or corroded at all. I have access to an ultrasonic cleaner that I submerge the gasket into a bath of IPA/DI water, heat it up and ultrasonic clean them. I then spray the gasket both sides with Permatex Copper Spray-O Gasket offered by NAPA, item # 765-1226. I've reused a Cometic MLS set several times on one of my nitrous motors that I sprayed with 300hp 2 stage nitrous often. No issues. The last time I had the heads off because I torched out from #3 cyl after fuel noid failed closed on a big run, cut a trench in the aluminum head right under the head gasket. I repaired the head, reused the gasket, continued running the rest of the season spraying copious amounts of nitrous, running low 10's at 140. Hows that for a test?!
Robert / Gen 3 MS
Old Jun 19, 2005 | 11:01 AM
98Pace6sp's Avatar
98Pace6sp
Thank you to all for your information and results. Robert from Gen 3 Motorsports is local highly respected tuner. I'll try his method and if I run into problems he's already offered help in the past. Great people at Gen 3 Motorsports. As usual, it appears clean, clean, and re-clean is the key. Again thank you all for your information.
Old Jun 19, 2005 | 11:53 AM
pdd000's Avatar
pdd000
ive had my heads on and off severel times and reused the same cometic gaskets every time with no problems
Old Jun 19, 2005 | 05:52 PM
Mike94ZLT1's Avatar
Mike94ZLT1
If you are spending all that time and money on a heads and cam swap why the hell wouldn't you buy new gaskets just for the simple peace of mind factor!?
Old Jun 19, 2005 | 06:18 PM
98Pace6sp's Avatar
98Pace6sp
I hear ya. Time; well for me its fun to work on my car. I learn more and more every day especially from this great forum. Cost; well I can well afford it, but if it's not needed, as others have posted, I can give it a try. If it doesn't work, removing the heads is much easier then many imagine. In the past I worked on my '95 Trans-am with an LT4. This corvette is so much easier then that car was/is. Again thank you so much for all your opinions and experiances,
Kevin
Old Jun 19, 2005 | 08:06 PM
Phil97SVT's Avatar
Phil97SVT
I've reused mine 4 times now. Clean them up with a good engine degreaser and hit them with copper spray.
Phil
Old Jun 19, 2005 | 08:15 PM
boblackhardtop's Avatar
boblackhardtop
for DIY reusing them may make sense but when you have to pay someone else and then wait for it to get done then I'd rather plunk down the add. $200.
Old Jun 19, 2005 | 08:23 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
A lot of people do reuse the Cometics, the choice is yours.
To Reuse Cometic head gasket?
