Ported 2.5 ls6 or 5.3 heads ???
Old Jun 19, 2005 | 11:53 AM
C5-JIM's Avatar
C5-JIM
Default Ported 2.5 ls6 or 5.3 heads ???
Ported 2.5 ls6 or 5.3 heads ??? Which are the best to use?
thanks, Jim
Old Jun 19, 2005 | 12:31 PM
fsuforever's Avatar
fsuforever
thanks, Jim
that question has alot of variables in it what application do you have to the motor right now ? are you gonna spray it ? cam the car ? supercharge it ? then you would wanna askyourself whats the appropiate size cc chamber i wanna run with the intended application hmm ?
Old Jun 19, 2005 | 09:14 PM
Mitch C's Avatar
Mitch C
All else being equal LS6 heads will out flow 5.3 heads. Thus making a bit more power.
Old Jun 19, 2005 | 10:03 PM
88sk's Avatar
88sk
from TSP,they say unless you go bigger cam or displacement wise then ls-6 heads are good,I got 5.3 heads from them,theyre higher comp. so more HP.,gotta 224/581/116cam,it all depends on your goal,if eventually you wanna go big then get the ls-6 heads.
To Ported 2.5 ls6 or 5.3 heads ???
