02 sims on a 98
im getting
p0161
p0153
p1133
with 02 sims installed im still getting these
i know at least one of these is for the rear
which code is which and do 02 sims work on a 98?
this is my second set of 02 sims doing the same damn thing
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
Bank 1 is driver side, Bank 2 passenger side
Sensor 1 is pre-cat, Sensor 2 is post-cat
You codes cover 3 of the 4 sensors, so you may have a problem common to them like wiring harness, ground, or PCM.
The service manual explains each code and lots of good info on diagnostics including specific causes for each of the different O2 sensor codes. Each sensor has about 6 different codes.
ok this is exactly what i was looking for
i get what the bottom 2 codes are but what is a heater circuit code?
I took the o2s out and now im getting only 153 and 1133
