catch can
Old Jun 20, 2005 | 10:35 PM
c5krazy's Avatar
c5krazy
Default catch can
need some help with oil catch can, i have already purchased and will install this weekend. question is, is the pvc in the small hose loop that is directly behind tb or is it the hose and metal tube out of valve cover on pass side. car is an 04. i read that patches had pix of hose routing but i could not find the thread. thanks for the help. the info gathered on this board is great. russ
Old Jun 20, 2005 | 10:45 PM
ArKay99's Avatar
ArKay99
The PCV valve is the wart in the tube that goes into the passenger side of the intake manifold right behind the throttle body. The 'low' pressure side. The tube that goes from the back of the tb to the passenger side valve cover is also part of the PCV but is the 'high' pressure side.
Route from the valley cover to your catch can input, then from the catch can output to your pcv valve, and plug that into the manifold as before. Leave the tb to valve cover tube in place.
Old Jun 22, 2005 | 04:15 PM
c5krazy's Avatar
c5krazy
thanks for the info, installed last night, worked good, no problems. russ
Old Jun 22, 2005 | 11:55 PM
Last C5's Avatar
Last C5
The 04 is different than earlier models. Patches has some good pictures and you can go to http://www.redgto.com for some excellent hose routing pictures. (Just ignore the mounting instructions)
To catch can
