Rear differential fluid change
Old Jun 21, 2005 | 12:59 PM
Joe's Eray's Avatar
Joe's Eray
Default Rear differential fluid change
How much can I expect to pay to have it done?
Old Jun 21, 2005 | 02:16 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Only a few bucks in material and 20 minutes time. Should not be more than $50.00 - $60.00
Bob
Old Jun 21, 2005 | 02:22 PM
MHVette's Avatar
MHVette
I paid almost $50 for labor since I provided Redline Tranny & Diff fluid. I'll do it myself next time!
Old Jun 21, 2005 | 02:57 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yea, do it yourself for sure. Get a suction gun from Harbor Freight for $4.95 and Redline (~$40.00) and 20 minutes of your time.
Old Jun 21, 2005 | 08:34 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
This is really easy to do yourself. Drain bolt is on the bottom. Fill plug is on the back (10mm hex nut maybe?). I don't even jack my car up to do this for the diff, but it makes it a little easier. I do need to jack it up and put it on Rhino ramps for the tranny.
Takes two quarts of synthetic 75w90 and a hand pump.
I use these:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
AMSOIL Hand Pump
AMSOIL Ordering Information
AMSOIL Preferred Customer Program
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 21, 2005 | 10:37 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yeah, you got it 10mm hex, if someone doesn't have one and you have a 10mm allen wrench-you can cut a 1 inch portion of the wrench and combined w/ a 10mm socket you've got the bit(just makes it easier then trying to get in there w/ a wrench)
Old Jun 21, 2005 | 10:40 PM
vetred's Avatar
vetred
I use these:
AMSOIL Hand Pump
with "Obie Wan" bingo!
Old Jun 22, 2005 | 02:53 AM
coast7's Avatar
coast7
Don't forget to add the "limited slip differential additive" if you are draining and refilling the diff. fluid. Its inexpensive and available at most autopart stores.
coast7
Old Jun 22, 2005 | 08:15 PM
C66 Racing's Avatar
C66 Racing
coast7
Most high performace diff fluids, such as the AMSOIL Severe Gear line, come with the friction modifier in them. I use this gear lube and do not use the friction modifier and I have no chattering issues. AMSOIL does say that if your diff chatters, it is safe to add a bottle of the friction modifier. I only have one of my hundreds of customers who actually uses this.
AMSOIL Slip-Lock Differential Additive
Old Jun 23, 2005 | 09:05 PM
berryj's Avatar
berryj
How often should the diff fluid be changed?
Old Jun 23, 2005 | 09:29 PM
SteveDoten's Avatar
SteveDoten
w/ a blower like yours, yearly , i think the gm shop manual says 100k
Old Jun 24, 2005 | 06:22 AM
owner C4 & C5's Avatar
owner C4 & C5
Due it your self. With our club discount I got the stuff from GM dealer for less then $16.00 two 22 oz and one 4oz add plus a screw on tube to fill with.
To Rear differential fluid change
