Engine light on, codes P0133 and P0153?
Old Jun 22, 2005 | 02:24 PM
T_Anderson's Avatar
T_Anderson
Default Engine light on, codes P0133 and P0153?
I put on a set of LG off road longtubes a few weeks ago and all went well until last weekend. My engine light came on and is throwing a p0133 and p0153 code. I know this means h02s slow response but what do I do to fix it? I have new 02 sims installed and like I said it worked great for a few weeks.
Old Jun 22, 2005 | 02:30 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Hello From Lake Zurich T ANderson just down the road from ya
sounds like you need to check the 02sims, maybe you got a bad one or hooked them up the wrong way??? It's easy to cross them up...
good luck
Frank
Old Jun 22, 2005 | 02:47 PM
T_Anderson's Avatar
T_Anderson
Hey Frank, thanks for the advise. I will check to see if there hooked up backwards. If that's the case, I wonder, would they work for a week then throw a code? How do you tell if they are hooked correctly?
Thanks,
I pass through Lake Zurich almost every day! I Work at Chicago Sea Ray 12 and 120 in Volo........
Old Jun 22, 2005 | 07:43 PM
T_Anderson's Avatar
T_Anderson
ttt
Old Jun 23, 2005 | 09:11 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
you know what, scratch my suggestion about having the O2's hooked up wrong, you would know it most likely right away, I had this problem and it caused the car to misfire.
I think you have a bad 02 sim or something along that line.
PM me sometime if you want to hook up.
Good luck
To Engine light on, codes P0133 and P0153?
