Brake bleeding problems, Help PLease
Old Jun 22, 2005 | 04:33 PM
CVETTE98's Avatar
CVETTE98
Default Brake bleeding problems, Help PLease
I just had all my calipers off and epoxy painted them and put on new stainless braided lines and new rotors. everything is back together and no leaks.
Problem is that I have ran over 1 quart of brake fluid through the lines both with my power bleeder and by using the bleeder screws with check valves and pumping the pedal and I still have spongy brakes? I tried the power bleeder first then used the valves that I already had on the calipers. I do RR LR RF and LF sequence. The first time I press the pedal it goes all the way to the floor. Then I can pump it up. Any Ideas?
PS:
I have a new Motive power bleeder
I think I know the answer. I have the bleeders on the bottom. I have to switch Calipers.
Old Jun 22, 2005 | 04:43 PM
t56gen3's Avatar
t56gen3
Hmmm is there a bleeder on the ABS module?
Old Jun 22, 2005 | 04:45 PM
CVETTE98's Avatar
CVETTE98
I have the Calipers on wrong. Two more hours and I will have it fixed. Thanks. I have to have the bleeders up!
Old Jun 22, 2005 | 04:51 PM
t56gen3's Avatar
t56gen3
HA!
At least it's something simple!!
Old Jun 22, 2005 | 06:21 PM
RoHo's Avatar
RoHo
You answered your own question, bleeders always on the up side
Old Jun 22, 2005 | 06:52 PM
csexton's Avatar
csexton
Old Jun 22, 2005 | 07:49 PM
Jackal's Avatar
Jackal
yeppers
Old Jun 22, 2005 | 07:52 PM
CVETTE98's Avatar
CVETTE98
Changed them and things work perfect now. These are the first I ever painted, I will know next time. Think that powder coating might be the way to go? The epoxy is real messy.
To Brake bleeding problems, Help PLease
