M6 transmission failure
Old Jun 22, 2005 | 08:28 PM
yzfrr1's Avatar
yzfrr1
Default M6 transmission failure
As you know, the shifter will not go into reverse if the car is moving forward because of the reverse lock-out gate.
But over the last few days, when shifting from 4th to 5th, the shifter DOES enter reverse instead of 5th. Fortunately, I've noticed this in time not to release the clutch.
Is anyone familiar with this type of transmission failure? Is it common?
Thanks!
Old Jun 22, 2005 | 10:49 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
probably just a bad lockout solenoid
Old Jun 22, 2005 | 11:21 PM
chriswtx's Avatar
chriswtx
That or a bent shift fork....
Old Jun 23, 2005 | 04:03 PM
tpocock's Avatar
tpocock
yes, they can go out.
I just had mine replaced on a 2003 ZO6.
It also started as an intermittent problem.
To M6 transmission failure
