Competition driving mode
Old Jun 23, 2005 | 12:36 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Competition driving mode
I was asked a question today by an owner of a 2004 coupe with AH. He wanted to know what changes in the car when it goes to Comp driving mode on the DIC. He activated it by pressing the AH switch. I have a no option 98 so I can't answer his question. I told him I thought it changed something in the shocks but don't hold me to that answer. I knew if I asked here I'd get the correct answer. Thanks.
Old Jun 23, 2005 | 12:43 PM
zguy's Avatar
zguy
Competition mode disables AH and TC.
Old Jun 23, 2005 | 12:45 PM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
zguy...that's incorrect.
Comp mode leaves AH on but TC off.
Old Jun 23, 2005 | 12:57 PM
simpleman68's Avatar
simpleman68
In simpler terms, comp mode maintains the vehicles ability to brake each wheels individually to maintain a straight and controlled course.
And, it disables the throttle control that reduces throttle when your wheels slip. (activates when there is a difference between actual vehicle speed and wheel speed)
Only by selecting the "off" mode does it eliminate both of the above features.
Scott
Old Jun 23, 2005 | 03:53 PM
zguy's Avatar
zguy
USMUSCL,
Thanks, I stand corrected. The learning continues...
Old Jun 23, 2005 | 04:01 PM
2kbluestreak's Avatar
2kbluestreak
When in "normal" active handling mode, if the car spins or plows, along with applying the brake to one wheel, the engine's power is shut off, either by cutting the fuel or the spark. This dramatically slows the car down and there is a couple second delay before you can pick up on the power again . In Competition Mode, you can get back on the power immeadiately. CM may also allow a little more yaw if you are in power induced oversteer.
Old Jun 23, 2005 | 05:13 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
that is interesting, i didnt know that active handling also alters the fuel and spark transmission.
so what is traction control (does it also limited wheel spin by applying the brakes) and how is it different than torque management?
Old Jun 23, 2005 | 05:45 PM
JeremyMSG's Avatar
JeremyMSG
Torque management is only on A4 cars in an effort to prolong the life of the 4L60E tranny. In GM's opinion, it was not strong enough so they put in a program to reduce engine torque between shifts and in other areas of the power band where tranny damage was likely to occur
Old Jun 23, 2005 | 06:21 PM
simpleman68
My tuner removed torque mgmt. from my m6, so there must be some form of it as well in the stick cars.
He explained that it was orig. in A4 cars but was also implemented in the manuals to reduce wear and tear on the tranny.
Scott
Old Jun 23, 2005 | 06:22 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
I understand the purpose of torque managment, but I was wondering how it actually works. I think it has something to do with altering the spark timing, but i am not sure. Doesnt traction control also limit torque to the rear wheels, how does it do so (by applying brake pressure?)?
Old Jun 23, 2005 | 07:00 PM
Paras's Avatar
Paras
Hee hee... it does!
Old Jun 23, 2005 | 07:05 PM
JeremyMSG's Avatar
JeremyMSG
Sorry, just call me Mr Obvious I have no idea how it actually accomplishes the power reduction. I would guess you are right and that it would simply pull timing, but I do not know for sure
Old Jun 23, 2005 | 07:07 PM
JeremyMSG's Avatar
JeremyMSG
Scott
I am starting to feel dumber...which it is hard to go lower than zero I did not know they ever put TM on the M6 cars. I wonder why they would do it in later models but not early ones
Vette_Fan's Avatar
Vette_Fan
WRONG answer...
Comp mode disable the Traction control, but the Active Handling is still ON. If you wanna shut OFF both TC & AH you'll have to turn OFF the AH button (in DIC it'll show OFF). Comp mode gives you maximum torque at rear wheels at all times, while still saving your A$$ from going out of control or in a spin... That's the easiest way to explain.
Drive carefully...
Old Jun 23, 2005 | 07:36 PM
2KFRC5's Avatar
2KFRC5
Here's some reading material, if you so desire.
http://c5registry.com/NewsRL/press1.htm
http://www.corvetteactioncenter.com/...1061997_4.html
http://www.idavette.net/hib/ah1.htm
http://www.chevrolet.com/safety/tractioncontrol/
Electronic Traction Control
A full-function traction control system is standard in every Corvette. The system limits wheel slip under power through brake intervention. If the system detects that either or both of the rear wheels are spinning, it will brake the wheel until both rear wheels are rotating at the same speed. The system can also be shut off, if desired, for certain road conditions, such as deep snow.
Old Jun 24, 2005 | 01:57 AM
SpeedyZ's Avatar
SpeedyZ
That should be...
Originally Posted by Correction
Comp mode gives you maximum torque at rear wheels at all times, while still attempting to save your A$$ from going out of control or in a spin...
Old Jun 24, 2005 | 01:04 PM
georgec114's Avatar
georgec114
OK...Because today in a "cranky Friday" to me, I'll answer this way:
Doesn't anyone have an owner's manual anymore?
It's explained in full detail. Read the freakin' book.
Old Jun 24, 2005 | 01:29 PM
jawsski's Avatar
jawsski
.....just us girls 'clucking' to pass some time.
To Competition driving mode
