first time changing rear end fliud.
Old Jun 23, 2005 | 10:22 PM
Vettegetsmwet99's Avatar
Vettegetsmwet99
Default first time changing rear end fliud.
i want to change my rear end fluid this weekend, i was wondering what is the best stuff the use and the easist way to put it in.
Old Jun 23, 2005 | 11:05 PM
silverz06vette's Avatar
silverz06vette
http://forums.corvetteforum.com/show...049&forum_id=1
Old Jun 24, 2005 | 02:05 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Diff takes two quarts of synthetic 75w90. To drain, there is a nut on the bottom of the diff (13/16th socket I believe but am not 100% sure). The fill plug is on the back (10mm hex). You will need some sort of hand pump to get the oil up into the fill plug. It really takes about 1.75 quarts until oil starts coming out of the fill plug, which is full. The job is really pretty easy.
It also takes a bottle of friction modifier (slip-lock modifier) unless your fluid comes with this pre-added. The AMSOIL gear lubes come with the friction modifier in it (and I don't use it).
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90
AMSOIL Hand Pump
AMSOIL Ordering Information
AMSOIL Preferred Customer Program
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 24, 2005 | 03:14 PM
MHVette's Avatar
MHVette
Everyone has an opinion on this one RedLine, AMSOIL, etc are popular.
After researching diff & tranny fluid I went with RedLine... Ordered off the web & took it to a local shop to change it out for about $50. Manager had previously owned 2 vettes so I felt pretty safe!
I'll do it myself next time - Good Luck
To first time changing rear end fliud.
