A/C Help Needed again....
SOme peeps said to reset the Dampers and also said my Freon was low..
I reset the dampers and that did nothing..
Then bought a can of R134a Freon with a pressure gauge built in..
Hooked it up to the low side and the pressure read dead in the middle of the Normal pressure.. Up to 45psi is Normal.. So I said screw it and added more freon till it hit right on the 45psi mark..
Still NOTHING... The temps felt the same inside the car, Cool not COLD like it did when it was new.....
I noticed a few other things.. The Low Pressure Metal hose was Cool to the touch but not the usual Freezing cold and almost frosted... And... It looked like the compressor was running the entire time... or at least I could not hear it switching on and off. I did hear the fans switching on and off as if the compressor was doing the same..
What could be the problem... I am really concerned that the low pressure line is NOT That cold.. I have never owned a car that the low pressure line was not absolutely FREEZING....
Maybe the pressure switch is bad and it's not letting the compressor really pump up before shutting off..
It sounds like you now have too much 134A in there now.
45PSI will give you an evap temp of about 50 degrees (not that cool)
Too much Freon is bad for your compressor also.
After 5 minutes of operation your low pressure reading has to be 30 to 35 PSI. Then the return line and your evaporator will be at that familiar freezing to the touch temperature.
Pressure is used to determine temperature and for 134A, 30PSI is just above freezing.
I hope this helps
D
You didn't mention you met these conditions in the 45 psi notes.
One disadvantage of only suction gauge is you don't know what the high side is doing. I would expect the high side to be 230 - 260 set as I described. If you can get a gauge (not the one you bought) on the high side and find you are over 260 you are over charged or have a restriction such as a plugging orifice tube. If below 230 or so you could have a compressor failing.
Best of luck,, 99 Nassau Blue
I did have the A/C on High with full fans and vents open.
It was about 95 degrees outside when I did it
Also, I checked the pressure before I added any more Freon and it was 35psi. But again at 35psi I was still having the problem.
I will let out some freon to get it back to 35psi. I know.... Bad for the atmosphere...
As far as the High Pressure side.. you are right.. I don't really know. I do not have a set of gauges to test it..
Although it's possible the compressor could be bad.. Let's assume for a moment it's good.. And I have a full charge.. What else should I look for? As I said earlier.. The low pressure tube is BARELY COOL.... hint number one.. The high pressure tube is however it's typical SCALDING HOT! Does that prove the compressor is working??
Two things come to mind: first, check your condensor and see if it's plugged up with some debris. Remember the fans pull air only secondarily through the condensor.
Second, you could have a bad expansion valve, but the only way to check it is to take a high pressure reading. Autozone has a decent set of gauges for R-134a for $50, everything you need.
Your compressor should run continuously during your test, so the pressure switches seem to be OK. You could have a bad compressor, but again a set of gauges will tell the tale.
HTH, and have a good one,
Mike
Mike
Where would I check for Debris on the Condensor?
I think I will go to Autozone and see if I can just borrow a test gauge for the High pressure side.. Assuming I have good pressure and no clog at the condensor you think a bad expansion Valve???
To replace this I imagine the system must be evacuated and done professionally?
Just visually examine the condensor in front of the radiator from underneath the car. Also, I wouldn't try to lower the low side pressure in your system, there's a relationship between the pressures and the ambient air temps. As far as AZ's tool checkout goes, I don't know if they've got gauges for public use or not.
I hate to sound picky, but you really need a set of gauges to get this checked out.
Lickitydo,
Once again, don't just plug a can of freon into your system because you don't think it's cold enough. Since we don't have sight gauges anymore, the only thing you can go by are the system pressures. Actually, there is one thing you can watch for: if your compressor clutch is running steady without disengaging after two or three minutes, you've probably got enough freon in your system until you can get a set of pressure gauges to check the high and low side with.
Mike
Lickitydo,
Mike
Thanks Man. I got the Condenser and the Evaporator mixed up... I'll go check it right now.... Wonder if a plastic bag got stuck on it...
Lickitydo,
Mike
Well the perils of a lowered car.. Can't get under there to check...
I have to put her up on Rhino Ramps this weekend anyway to fix leaky directional Bezels... I swear I blow out bulbs every time I wash the car!
Also check that when you turn the a/c on that both fans on the radiator are running. If you only have 1 you won't get enough air to cool properly. You could just have a bad fan. 99 Nassau Blue
Ok, I am most certain the compressor is working or I would not get any cooling at all.. And the fans are ok because when I am moving at highway speeds the problem does not get much better..
I'll get her up on the ramps this weekend and check it out..
*****How do you reset the Dampers ???*******
