Thermostat swap question
Old Jun 27, 2005 | 01:01 PM
matt24's Avatar
matt24
Default Thermostat swap question
I just got a 160 thermostat and gonna swap it out i dont have to drain all of the dexcool do i, i can just swap it out and refill whatever gets lost? Thanks!
Old Jun 27, 2005 | 01:37 PM
byte_me's Avatar
byte_me
When I did my t-stat install I lost quite a bit of fluid...even when pulling the hose off and lifting it up high I still dropped out a jug of coolant and almost a whole gallon of distilled water! Just be prepared to replace that amount...I had those on hand so it wasn't too bad- but it was a mess! be careful tightning those bolts back as well...its all aluminum and can easily strip out as you tighten her back up...by the way, I went with a 180 t-stat and dropped almost 25 degrees off my normal driving temps!
Old Jun 27, 2005 | 02:08 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
According to E-T, if you have everything set and ready and are quick and the engine cool, you can do it with minimum coolant loss. I lost about a 1/2 gal or more when I did it, oh well..
Old Jun 27, 2005 | 04:07 PM
FKING1's Avatar
FKING1
Put a bucket under the car and drained until below thermostat level. Poured the captured coolant back in.
Fred
Old Jun 27, 2005 | 04:34 PM
matt24's Avatar
matt24
Cool thanks, isnt it bad if some of the coolant gets on some or any of the engine parts?
Old Jun 27, 2005 | 08:26 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I didn't lose hardly any. Just be ready to do the switch. Follow these instructions.
Old Jun 27, 2005 | 09:44 PM
jcgordon's Avatar
jcgordon
Make sure you don't let air get into the system. Vettes are a pain to purge air from the cooling system and trapped air will cause the car to run hot.
To Thermostat swap question
