Help! Seat doesn't move forward or backward
Old Jun 28, 2005 | 07:39 PM
tk97's Avatar
tk97
Default Help! Seat doesn't move forward or backward
I would usually do a search on the topic first, but I don't have the time right now as I gotta be somewhere soon. Got into my car a few minutes ago to find that the seat does not move forward or back, only up and down. When I push the button forward or back to make the seat move I hear a clicking noise, like the motor is trying to work, but there is no movement. Could this be a fuse problem? Any help would be much appreciated!
Old Jun 28, 2005 | 09:38 PM
tk97's Avatar
tk97
Anyone? I really need to fix this because it is not set in my usual seat position.
Old Jun 28, 2005 | 09:53 PM
mrtoner's Avatar
mrtoner
tk97
You don't by chance have sheepskins on your seats, do you? Reason I ask is I had my seat refuse to move, and found that one of the straps for the skins had slipped into the gear train and locked it up.
If you don't have the skins, I don't know...
Old Jun 28, 2005 | 10:03 PM
tk97's Avatar
tk97
Originally Posted by mrtoner
tk97
No, I don't have sheepskins. Although, now that you've mentioned it, could it be possible that something has got stuck on the track or gear train causing it to look up?
Old Jun 28, 2005 | 10:19 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
ANy codes ?
I fixed mine
Pull seat look at connectors under seat see if they are damaged or have pins coming out. If the search function worked i created topic for telescopic wheel fix and you can find some info there.
Old Jun 28, 2005 | 10:23 PM
tk97's Avatar
tk97
Originally Posted by NOT-MEE
ANy codes ?
I fixed mine
The first thing I did was check for codes. Nothing showed up. I guess I will have to get under there somehow and check for any loose connections. I really hope the motor has not gone. Thanks for the replies.
Old Jun 28, 2005 | 10:24 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
look at this topic
http://forums.corvetteforum.com/show...xed&forum_id=1
Old Jun 28, 2005 | 10:27 PM
tk97's Avatar
tk97
Thanks, NOT-MEE. That was really informative. I'll take the seat apart first thing tommorrow and let you know what I find.
Old Jun 29, 2005 | 01:10 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Both of mine died. The pass seat must have gotten a little water on the PC board in the switch and it corroded, a little solder and now its fine. The driver seat had a broken wire going into the plug under the seat. I pulled it out and fixed that one too. The seat unbolts very easily.
Old Jun 29, 2005 | 01:15 PM
tk97's Avatar
tk97
I'm hoping it's a broken or disconnected wire. Will let you know soon.
Old Jun 29, 2005 | 01:54 PM
Jackal's Avatar
Jackal
I had the exact same problem with my car. I found that one of the connectors under the seat had a broken wire piece inside of the connector. I had to do some fancy soddering to get it fixed. It was not easy to find either. I had to hook the seat up while out of the car and wiggle each wire while moving the seat forwards and backwards to find the broken wire. If I remember correctly, the wire that was broken was a puke green.
Good luck, its not that bad, just takes patience.
Old Jun 29, 2005 | 04:52 PM
tk97's Avatar
tk97
Well, found the cause and that's the exact same problem as mentioned above! Green wire has broken off and it's right behind one of the motors making it almost impossible to get too . I took the seat to a local mechanic/friend of mine and he said he would take care of it. I don't have the time or patience right now to sit there and play with wires.
Old Jun 29, 2005 | 09:51 PM
SilverC5Vert's Avatar
SilverC5Vert
My telescoping wheel also does not work and to move the seat back you have to hold the switch down and back at the same time!?! I pulled the seat today and found 2 black wires and a purple wire pulled out and replaced them. That didn't seem to fix anything and it does the same thing. There doesn't seem to be any other wires loose or broken... any ideas?
Thanks,
Rick
Old Jun 29, 2005 | 10:47 PM
tk97's Avatar
tk97
Thanks,
Rick
Does anyone know if there are any fuses or relays that could be linked to this problem?
Old Jun 30, 2005 | 07:07 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
The switch could be bad or might be a dirty switch.
Old Jun 30, 2005 | 09:58 PM
SilverC5Vert
It's got me stumped... I'm thinking it may be the switch, however it's weird that the telescopic wheel doesn't work either...
-Rick
Old Jun 30, 2005 | 10:29 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
-Rick
Use the link I provided in earlier post. Take the connector apart under seat the orange wires are the tele wires. Look for any pins pulling out of connector. Thats where my issues were.
Old Jul 17, 2011 | 01:10 PM
TheeMike's Avatar
TheeMike
Thanks,
Rick
What did you find to fix this? I am having the exact same issue.
To Help! Seat doesn't move forward or backward
