knocking pinging
Old Jun 28, 2005 | 09:31 PM
babalu95's Avatar
babalu95
Default knocking pinging
Help. My vette keeps knocking and pinging. Sounds like a diesel engine when climbing the rpm's from about 1300-2000, but for a few seconds. I've added fuel system cleaner, replaced the fuel filter, and changed the plugs. It went away for a day or two when I changed the plugs this weekend. But, now it's back. The service advisor at Chevrolet advised me it might be carbon buildup and may require a cleaning via some solution sprayed into a vacuum hose on the engine. But, before I pay them to do anything again, I was hoping someone out there has experienced this and had advice.
Old Jun 28, 2005 | 10:38 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Try some Torco!
Old Jun 29, 2005 | 08:26 AM
babalu95's Avatar
babalu95
ttt
Old Jun 29, 2005 | 11:20 AM
FRCTony's Avatar
FRCTony
http://forums.corvetteforum.com/sear...t=on&forum_id=
Old Jun 29, 2005 | 01:11 PM
not08crmanymore's Avatar
not08crmanymore
Default pinging
pinging=bad gas.try dry gas and put in sunoco or hess or texaco,if you;re using some other brand.
Old Jun 29, 2005 | 01:36 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
I used to swear by Sunoco, until I learned that it was a blend and had methanol in it.
I am running Amoco gold now and the slight pinging problem I had when I was running Sunoco 94 octane is all but gone now.
Old Jun 29, 2005 | 10:23 PM
jcgordon's Avatar
jcgordon
Try adding Xylene to your gas. You can buy it at your local Home Depot or paint store. Do some research on the internet about using xylene and toluene as octane boosters. It takes a lot of it to actually raise octane but I have found that about 32 ounces stops my vette from pinging. My best advice is to use only enough to stop the ping and that may take some experimenting. Your car may need more or less than 32 ounces to stop the pinging. It all depends on the car.
You can learn more about xylene at the website below.
http://www.idavette.net/hib/fuel/page2.htm
To knocking pinging
