Can someone explain this code??
Old Jun 29, 2005 | 09:37 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Default Can someone explain this code??
It's under 99HVAC. Code B0367 Right Actuator feedback open. I cleared it once & it came back under history.
Thanks!
Ron
Old Jun 29, 2005 | 03:31 PM
Dr.Ron's Avatar
Dr.Ron
N E 1??
Old Jun 29, 2005 | 06:10 PM
Geneus's Avatar
Geneus
ttt...help the brother out!
Old Jun 29, 2005 | 10:33 PM
Dr.Ron's Avatar
Dr.Ron
I can't believe that nobody knows the answer.....????
Thanks Don!
Where are all of the techies??? Maybe I should have included a poll for who looks back at their car after they lock it up, or one of these other silly threads that gets 3000 views & 300 posts to them...
Ron
Old Jun 29, 2005 | 11:04 PM
Geneus's Avatar
Geneus
Ron,
Time to go over you "know where and post this"...someone there will know.
Old Jun 29, 2005 | 11:07 PM
Geneus's Avatar
Geneus
Originally Posted by Dr.Ron
It's under 99HVAC.
Gee, Ron...an HVAC code. Maybe our resident expert racer (and part time HVAC engineer) Yo-El would know.
Old Jun 29, 2005 | 11:36 PM
VLVETTE's Avatar
VLVETTE
ttt
Old Jun 29, 2005 | 11:54 PM
VLVETTE's Avatar
VLVETTE
[QUOTE=Geneus]Ron,
Time to go over you "know where and post this"...someone there will know. [/QUOTE
Where are you talking about I'm getting the same code for the left side???
Old Jun 30, 2005 | 12:02 AM
Dr.Ron's Avatar
Dr.Ron
[QUOTE=VLVETTE]
Ron,
Z06vette.com.
Dr.Ron's Avatar
Dr.Ron
Old Jun 30, 2005 | 02:24 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Dr Ron. Give this a try. It won't cost you anything and sometimes it will clear the problem.
Quote from another post...
have this happen to me everytime I disconnect the battery. Once I have the battery connected I turn the key on, HVAC off, pull the fuse for the HVAC (I think it is #27), wait a couple of seconds, replace the fuse, and clear the codes in the DIC. I think the loose connection when replacing the battery cable makes the HVAC go nuts. This resets the HVAC and away you go.
Old Jun 30, 2005 | 11:26 PM
Dr.Ron's Avatar
Dr.Ron
Is this fuse located by the battery?
Thanks!
Ron
Old Jul 1, 2005 | 12:02 PM
Threed's Avatar
Threed
Yes it is. Others have stated that they removed 3 fuses. But I don't see that in the GM instructions. There are more in the footwell.
To Can someone explain this code??
