Anybody know these codes?
Old Jun 29, 2005 | 06:14 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default Anybody know these codes?
B0367 and B0365
Old Jun 29, 2005 | 06:21 PM
SMOKNC6Z06's Avatar
0SMOKNC6Z06
Former Vendor
Here you go:
DTC B0365
Circuit Description
The HVAC control module commands the right air temperature actuator to move by controlling the voltage supplied on the control circuit. A low voltage of 0 volts moves door toward full hot. A voltage of 2.5 volts stops the door. A high voltage of 5 volts moves the door toward full cold. The HVAC control module determines the current position of the actuator by monitoring the voltage on the signal circuit. The feedback potentiometer is a function of the motor position. A high voltage of 4-5 volts indicates full hot door position. A low voltage of less than 1 volt indicates full cold door position. The HVAC control module controls the right air temperature actuator door positions in order to maintain the selected air temperature.
DTC B0367
Circuit Description
HOpe this helps.
Terry
Old Jun 29, 2005 | 07:04 PM
VA CORVETTE 757
Thank you so much!
To Anybody know these codes?
