LS2 Oil Pan C5 Retro...
Can anyone confirm that the new LS2 oil pan will clear a C5 chassis and provide no other additional complications....I "assume" it will but we all know how that can go sometimes....LOL
I plan on bolting it up to an LS1/LS6 style block as well....another "assumption" perhaps?
Anyone have some input here?
Much appreciatted...
Tony M.
BTW- Did you get me email?
Phil- DTE
Friday was a little crazy....yes I got it. I will call and discuss it with you next week.
Your response seems to perhaps imply the pan can be modified to fit? Let me know....even if the frame needed minor modification I might be up for it. What is the issue that makes it not a "drop in"?
Thanks,
Tony
Phil
The oil pans that come with the LS2 crate engines we purchase for our C5 engine conversions are the type I described above, but one could certainly purchase another C6 pan for the retrofit if they chose to. Outside of increased header side clearance using the LS2 pan in the C5 chassis, we couldn't see any *real* benefit of that pan for the additional cost involved...at least for our needs.
Tony, if your car needs that extra clearance for some reason, grab it.
Personally, I think the LS2 C6 pan would be the hot ticket for you turbo guys needing the extra room down there near the oil pan area. While I was with LPE a few years ago as a technician, I built/assembled 11 early twin turbo cars of various stages of performence levels and I can tell you from direct experience, there is NOT any extra real estate down under the car when two hair dryers with their related support components are crammed in between the car's body, the subframe and the oil pan.... I don't know how their doing it now, but I would guess they would have looked at the LS2 C6 pan by now...at least to see if it did actually work. Just a guess...
Phil- DTE
Thanks for everyone's input....
Tony
