Ive had a problem with a dyno tune recently but was too far away from the shop to get it fixed.They sent me a new pcm which was supposed to be programmed correctly.I had a shifting problem,which was taken care of,but my temps now get alot higher than before.I dont ever hear the first fan kick on!! Im about to hook it up to hp tuner to change them so if anyone has the fan settings for a 170 stat i would appreciate the help.
Now driving at 70 it stays in the 180 range,but at idle it shoots up to 230 fast.I realize its not hurting anything,im just couriuos what may have happened.
Didi you have your fans changed in the first tune, I bet they forgot them in the second tune. Regards, Jeff
I can almost bet that the new PCM has OEM fan settings.
you can set your 1st fan to kick on at 190 and to turn off at 185, the 2nd fan to come on at 197 and turn off 193. This is just to give you an idea of how they should come on and turn off. Make adjustments to suit your needs and geographical area.
My best advise is to get a laptop and HPTuners and D.I.Y. Regards, Jeff
I did exactly that and now i have no problems.The fan settings were in the 220-240 range.WOW. I thought i paid good money for somthing.Guess im better off doing it myself.Tq managment was still there as well as my shift points were wayyy off.Im so much happier with my car now!!
