Window is rubing a hole in convertable top
Old Jul 3, 2005 | 12:59 PM
Donmack's Avatar
Donmack
Cruising
Default Window is rubing a hole in convertable top
Have a 2000 convetable. With the top and windows up, if I close the door the window is rubing a hole in the back upper coner of the top. If I push the top edge of the window in as the door closes it clears the fabric top and seats in on the rubber seal OK. I check the adjustments for the "window tip" (front & back) both adjustments are set at max for top in/bottom out. Ive seen a number of vetts with the same rub hole in the top. Anybody have this problem and solve it? Thanks Don
Old Jul 3, 2005 | 02:37 PM
XTrooper's Avatar
XTrooper
I "solved" mine with a new top and manually pressing in the tip of the window (or lowering it slightly) before closing.
FWIW, I've rarely seen a C5 convertible top on which the upper corner(s) wasn't frayed.
Old Jul 3, 2005 | 02:51 PM
donnyonee's Avatar
donnyonee
i have the same issue but right now the vert is in the shop. i think that there is a adjustment for how far up the window raises.
ive read where the tip in is adjusted thru the relector? i think the height is adjusted thru the bottom of the door?
try that?
Old Jul 3, 2005 | 03:27 PM
AndrewNguyen's Avatar
AndrewNguyen
I had the same problem. I opened the top up and down a bunch of times and it dosen't do it anymore, but there is still a wrip.
Old Jul 3, 2005 | 03:56 PM
1stC5weiss's Avatar
1stC5weiss
I have the same problem on my 2000, if you find a good solution let me know as well...
Old Jul 3, 2005 | 04:15 PM
Autoworker's Avatar
Autoworker
Took mine to the dealer... they adjust the window to the top by moving the window forward slightly. works great. costs 100.00 but worth it.
Old Jul 3, 2005 | 05:30 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
When I had my 98 Vert I just put the driver’s window down a bit before closing door. **Disclaimer here, I normally drive top down and keep the car in a garage**
When I sold my C5 in the beginning of June no fraying showed.
Many of the C5 have this problem
Old Jul 3, 2005 | 06:07 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Mine did that when I first got the car, it's not supposed to do that but it is a common problem. I fixed it by adjusting the window tip in, and moving the window forward a little bit.
total cost......... $0.00
Old Jul 3, 2005 | 06:47 PM
white90conv's Avatar
white90conv
I don't see any unusual wear on my 2000 vert (50k miles). So apparently, the window can be adjusted to avoid the problem or there is a lot of variation in the tops themselves.
Old Jul 3, 2005 | 11:07 PM
GrayC5's Avatar
GrayC5
Convertible care, adjustments, and tips
To Window is rubing a hole in convertable top
