If we say that an A4/M6 loses 20/15% respectively, why are these expressed as a % and not a fixed number? Assuming the mechanicals that cause the loss stayed the same during an engine swap, wouldn't the drivetrain eat the same amount of HP no matter what was powering it?
Put another way, in an A4 with 400BHP we might expect a RWHP figure of 320. If we bumped that motor up to 600BHP, then the RWHP should only be 480. Why does the parasitic loss increase relative to the BHP?
I've wondered that myself. According to the % reasoning, the more HP/TQ you make, the higher the loss to the rear wheels. 350HP x .15=298HP (52HP). 600HP x .15= 510 (90HP). Huh?
Well I am not sure on this but I have always assumed that the 20%/15% worked well on a vehicle in the 300-400 crank HP range. I think as the crank HP goes up the % of parasitic loss to the rear wheels would decrease.
That makes sense - perhaps it is within a % range depending on crank hp, i.e. the % goes down as hp increases.
You would think that Dynojet or Mustang has done some research on this and has data that could be published. Anyone have contacts with either of these two companies?
I don't know, but I had my stock.....very stock 02 A4 coupe 3.15's dynoed and came out at 308.6RWHP and 321.1RWT???
If there's 18% then I'm over 375HP at the crank?? doesn't sound like there's really 18% loss if you ask me......or why would GM advertise 350HP vette??
If you have no power adding mods I would say that is a one in a million C5. Just from following the forum what I have seen with A4's is 287-299. Oh well be happy.
Transmission efficiency is defined as the ratio of output shaft power to input shaft power. 85 percent (i.e. 15 percent loss) is very inefficient for a manual transmission but not too far off for total driveline loss from the crankshaft to the road wheels (something like 10 or 12 percent loss might be more realistic). The efficiency of the transmission alone should be around 93 to 95 percent. The other losses are the propshaft bearings, final drive assembly, axle bearings, maybe some brake drag and tire flex. Also keep in mind that it's difficult and expensive to measure these things accurately so don't take the numbers too seriously, especially data from an inertia dynamometer. Steady-state measurement is the best but it requires a more expensive dyno.
I've heard of quite a few actually with around 305-310HP stock A4. But most of them are 04's with little miles.
I made sure I changed my gear fluid, trani fluid, oil, new air filter and had everything up to speed so I could get my best #'s as close to "like new" as possible. I'd bet most don't do that though?
....I still don't think it's 18% loss either.....I need to take mine to the 1/4 track and see if I have a freak or what, but it's getting real hot out, performance will be less.
Josh, were your dyno numbers SAE corrected and smoothed? If not, you will see power and torque numbers (higher than actual) not corrected for atmospheric conditions and your peak numbers will be spikes, rather than the smoothed peak. Personally, SAE corrected and smoothed numbers are the only ones I compare anything to. Dyno numbers give ballpark results and a base to look at when adding mods (if they're on the same machine). Just my personal opinion.
Ed
My 04 A4 with Z06 Ti exhaust, Z06 airlid, Fram air filter, and straight coupler (from the air bridge) dyno'd at 304.9 rwhp and 322.6 rwtq. Assuming that I got 10 - 15 hp from the mods (with various claims this s/b more like 25 hp ;-) then I would think that 305 - 310 rwhp is pretty strong for a bone stock A4. Just my $0.02.
BTW, my car had 2,600 miles on it at the time of this original dyno. I brought it to DTE for a cam package and Stage II differential.
Reason: Added comment about mileage
My 2000 FRC (MM6) with a 2004 crate LS1 replacement eng with Z06 airbox, K&N, 2000 (smaller 78mm) MAF & TB, stock 26# injectors, LS6 intake, and full '03 Z06 exhaust (cast headers, H pipe, Ti cat backs) dynoed at 324 RWHP/338 RWTQ at A&A. After 5 hours of work, Charlie was able to get it to 330 RWHP/344 RWTQ. Engine had 900 miles on it.
