Headlights Won't Shut Down?
Old Jul 4, 2005 | 06:57 AM
Vettesic's Avatar
Vettesic
Default Headlights Won't Shut Down?
Headlights come on when I start vette without turning switch on. Then when I try to shut them down they stay on. I have to shut car off and then start again to turn off lights. Sometimes that woks and sometimes not. Any similar problems with this? Is there a GM bullitin on this that someone knows about? Thanks, Paul.
Old Jul 4, 2005 | 07:21 AM
quimbo's Avatar
quimbo
IF u have twilight sentinal you may have to go into your DIC and turn it off hit options and see if u have the twilight sentinal option if u do shut it off
QUIMBO SEEYAAAH
Old Jul 4, 2005 | 09:29 AM
stevenll's Avatar
stevenll
Try putting the lights on high-beam & then shutting them off.
I ran into my lights staying up when I switched to hi-power Euro lights.
The high-beam position works for me.
Old Jul 4, 2005 | 01:23 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
doesnt that happen when you have a blown bulb??
Old Jul 5, 2005 | 08:03 PM
Vettesic's Avatar
Vettesic
I heard that the euro lights caused this problem however, I have the stock bulbs in. Guess I'll try your fix. I'll also look into the twilight sentinal issue. Also if there is a blown bulb.
To Headlights Won't Shut Down?
