Clutch Install Question
Old Jul 5, 2005 | 10:26 PM
mkern1's Avatar
mkern1
Default Clutch Install Question
Do you have to remove the entire bellhousing to install a Twin Disk Clutch such as the Mcleod? All of the diy guides show the clutch being installed through the flywheel inspection cover. Is a twin disk to big to fit through the inspection hole? Removing the entire bellhousing looks like a major pita!
Old Jul 5, 2005 | 11:05 PM
97 SC Cobra's Avatar
97 SC Cobra
I don't think it's possible. You might be able to get away with leaving the bellhousing on but I think it's easier to just pull it. Clutch installs are a major PITA on vettes compared to the mustangs I've previously owned. Dope has a great clutch tutorial somewhere on the forum.
Old Jul 5, 2005 | 11:14 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I installed my Exedy without removing the bellhousing.. not a problem.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Jul 6, 2005 | 12:39 AM
97 SC Cobra
The bellhousing is a little tricky to pull out. I had to loosen one header and turn it until it squeezed out.
Old Jul 6, 2005 | 08:42 AM
mkern1's Avatar
mkern1
Thats good to know. The only way I can see you can get to the bolts to remove the bellhousing, would be to lower the whole front subframe engine and all. Not a fun task!
Old Jul 6, 2005 | 09:28 AM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Most all the clutchs can be done with the bell housing in place. Only exception are the real thick duel disks where you might have to loosen the bell housing a little bit.
Old Jul 6, 2005 | 10:18 AM
Patches's Avatar
Patches
Here some pics of a Z06 clutch install we did on my buddy's '01 coupe. The pics show the clearance you have fairly well.
http://redshift.homestead.com/Clutch.html
Old Jul 6, 2005 | 10:42 AM
mkern1's Avatar
mkern1
OK, so I assume once the torque tube is droped the motor can be tilted enough to get to bolts to remove the bellhousing? Otherwise, I would have to completly drop the motor to get to them.
Old Aug 11, 2005 | 04:53 PM
mitymikec's Avatar
mitymikec
Does anyone have pics of installing the mcleod twin disc and pics of the bellhousing bolts?
To Clutch Install Question
