I have a 2000 Auto Coupe with about 17000 miles on it. The only maintainance I've done over the years is to change the oil. What other items should I consider? Coolant flush?
Yes. Get fresh Dexcool or equivalent in there ASAP. The stuff tends to build up a nasty brown sludge over time. You should be ok with that low mileage though.
The service writer suggested a new fuel filter and flushes for the
transmission and differential fluids. What is the opinion of these items
on a 17000 mile C5?
If you have the original battery (highly unlikely) thank your lucky stars you still have a computer, and replace it with an Optima or any good battery before it squirts acid all over your PCM.
