DIC info
Old Jul 6, 2005 | 06:43 AM
dugsc5's Avatar
dugsc5
Default DIC info
my light on the heat temperature controls is out. does any body know how to get it to light back up? is their a fuse to replace or is the problem more complicated???????????
Old Jul 6, 2005 | 11:08 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
If you are talking about the temp / mode display, the HVAC unit needs to be replaced. There is a place that repairs them, but you are looking at a couple weeks down time and the cost is nearly that of a new control unit from Beans or Fichtner. I did ours in our 98. It took about 1 1/2 hours. I could do it in 30 minutes now, because I have had the console off twice for other reasons. Do NOT buy one at your local stealership...order one from one of these forum vendors because you will save mucho bux. Once the console is out, it is 2 screws and plug and play.
Old Jul 6, 2005 | 11:15 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Replace it, it is another thing that happens to our cars that should not. For the price of the car that is another quirk
Old Jul 8, 2005 | 11:53 AM
airliner's Avatar
airliner
7th Gear
Any advice on how to remove interior components to access and replace the HVAC control unit for those of us that have not been in that area before??
Old Jul 8, 2005 | 04:31 PM
xlr8shn's Avatar
xlr8shn
Will take you < 5 min to get at the radio and HVAC controls once you've done it once.
Following the "removing center console" instructions listed here:
http://joshker99.home.comcast.net/hudinstall2.htm
Old Jul 9, 2005 | 04:50 PM
airliner's Avatar
airliner
7th Gear
Thanks for the link. Exactly what I was looking for
To DIC info
