adjustable rocker arms NEED HELP!!!
Old Jul 11, 2005 | 09:25 AM
1badws6's Avatar
1badws6
Default adjustable rocker arms NEED HELP!!!
anyone have patriots adjustable rocker arm i have a 98 c5 with patriot stage 2 setup heads and cam 224/224/-580 and there adjustable rocker arms is there a sequence to adjust these? i was told to tighten the adjuster until it bottoms out then back it off 1 full turn but that does noot seem to be working i also have installed comp R lifters in the car from what i have been told is that the preload on the comp R is different than stock has anyone used this setup or have a easy guide to adjusting the arms what i am experiencing is the valves opening when adjusting on certian arm due to not being on the base circle so i guess i need the adjustment sequence if there is any
any help would be appreciated
thanx
