98 or 99 C5 - differences??
Old Jul 13, 2005 | 11:59 AM
300bhp/ton's Avatar
300bhp/ton
Default 98 or 99 C5 - differences??
I notice that most of the hand held tuners (Diablo...) state 99-04 models only.
I assume that the 98's have a different ECU. Is this true?
Would there be any detriment to buying a 98 over a 99. I plan on a few simple mods at 1st and a Procharger later on. So being able to tune it easily will be a must, but Corvettes are quite specialist over here. Not even sure where I'd take it for tune, my local shop is so appaling I wouldn't let them tune a food mixer!
Also is there an easy way to tell the differences. As in the UK sometimes the years get mixed up and a 1998 car may well end up with a 99 registration. (This is just due to how the import regs work I think).
Any help will be aprreciated,
Ta.
Old Jul 13, 2005 | 02:18 PM
TurboWindsor's Avatar
TurboWindsor
The ECM/PCM is different, but that wouldn't hold me back from a 98' car. Use LS1 Edit or HP Tuners to do any of your programming. I would actually prefer a 98' for your blower application due to the return style fuel system working better (it's easy to retrofit to the 99'-early 03') to return.
Old Jul 13, 2005 | 05:00 PM
Face's Avatar
Face
For a blower car, 98 is definitely the way to go.
Old Jul 14, 2005 | 09:38 AM
300bhp/ton's Avatar
300bhp/ton
Right. It appears that getting a custom tune for a Corvette may not be that easy where I live. The easiest way would seem to be to take it to a rolling road and use a hand held unit like the Diablo.
1. Is the Diablo unit any good??
2. What can I do to check if its a 98 or 99 ECU? Is there anything visible?
3. If all else fails are there any hand held tuners for the 98 models?
Ta.
Old Jul 14, 2005 | 10:31 AM
ROJO99's Avatar
ROJO99
I believe the 97/98 cylinder heads mounted different also from the 99+ LS1's. Someone verify this please.
Old Jul 14, 2005 | 11:58 AM
G-lock's Avatar
G-lock
Vavle covers are different, 98 were perimeter bolt, 99+ center bolt. Jeff
Old Jul 14, 2005 | 05:59 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
The 98's have 2 fuel lines ,as stated above,the 99's have 1.Pop the hood and that should tell you
Old Jul 14, 2005 | 06:25 PM
lost's Avatar
lost
98s have the largest injector of any C5 including the ZO6, which means you can do a lot more modding before you have to worry about bigger injectors....
Old Jul 14, 2005 | 06:48 PM
flynbya2's Avatar
flynbya2
Really?? I did not know that!! awsome!
Old Jul 14, 2005 | 08:23 PM
ghost.rider's Avatar
ghost.rider
Yep, in fact one of the first things LPE does to 99's and later is put in bigger injectors.
Old Jul 15, 2005 | 10:21 AM
C5XTASY's Avatar
C5XTASY
1997, 1998 and 2001 through 2004 LS1s, and LS6s, all had 28.8 lb injectors. 1999 and 2000 had 26.2 lb injectors.
Ed
Old Jul 15, 2005 | 01:13 PM
xlr8shn's Avatar
xlr8shn
And here is the EASIEST way to tell 97-98 from 99-03 cars (assuming you can look under the hood):
97-98 cars will have TWO braided metal fuel lines connecting to fuel rail on U.S. drivers side (fuel pressure regulator on rail)...
99-03 cars will have ONE braided metal fuel line connecting to fuel rail on U.S. drivers side (fuel pressure regulator in fuel filter under car)...
Old Jul 15, 2005 | 01:16 PM
xlr8shn's Avatar
xlr8shn
Or checking VIN:
10th digit on the VIN will give you the year:
1997-V
1998-W
1999-X
2000-Y
2001-1
2002-2
2003-3
2004-4
Old Jul 15, 2005 | 02:20 PM
300bhp/ton's Avatar
300bhp/ton
cheers for the responses. Should be going to look tomorrow sometime.
To 98 or 99 C5 - differences??
