TWC System Low Efficiency Bank 1 code
Old Jul 13, 2005 | 02:39 PM
2003silvercorvette's Avatar
2003silvercorvette
Default TWC System Low Efficiency Bank 1 code
what does TWC System Low Efficiency Bank 1 mean ?
Old Jul 13, 2005 | 02:53 PM
torchredfrc's Avatar
torchredfrc
I believe this code is referring to the catalytic converter on the drivers side of the exhaust. Is the code set and staying or is it a code stored in the PCM history?
Old Jul 13, 2005 | 02:56 PM
2003silvercorvette
it said H C but i just installed high flow cats so thats probly why its throwing the code ?
Old Jul 13, 2005 | 05:40 PM
torchredfrc
Try clearing the codes and see if it comes back. It could be because of the Oxygen sensor after the cat too; do you have simulators or are you running the stock exhaust with the exception of the high flow cats?
To TWC System Low Efficiency Bank 1 code
By Michael S. Palmer | 2026-06-03 11:00:24
