Front lowering bolt stripped..now what?
Old Jul 13, 2005 | 07:57 PM
Turbooo2u's Avatar
Turbooo2u
Default Front lowering bolt stripped..now what?
Put in Z51 springs but cut the bushings first. wasn't low enough and I have room to go farther. Relieved the tension on the spring and went to lower but stripped the SOFT 10mm top bolt. Can I thread a nut onto the top bolt and get the bushing up this way..HELP!
Old Jul 13, 2005 | 08:00 PM
turboc5's Avatar
turboc5
If you can fit it try jam nutting 2 nuts together and then turning it. If not vice grips but NOT on the threds.
Old Jul 13, 2005 | 08:03 PM
Turbooo2u's Avatar
Turbooo2u
What size nuts??
Old Jul 13, 2005 | 08:22 PM
turboc5's Avatar
turboc5
I don't know, but they probly are metric.
Old Jul 13, 2005 | 08:27 PM
C5 ChemE's Avatar
C5 ChemE
what is "jam nutting", and how can I do it?
I had the same problem stripping my nut
Old Jul 13, 2005 | 08:56 PM
turboc5's Avatar
turboc5
put 2 nuts on the stud and tighten them against each other (not the spring) jamming them together. Then it locks to the stud turning it into a bolt. but thats only if their is enough room
Old Jul 13, 2005 | 11:33 PM
Turbooo2u's Avatar
Turbooo2u
My Vette mechanic buddy says he can fix it using the old bolts from the other spring without taking down the spring again. I hope!
To Front lowering bolt stripped..now what?
