underdrive pulleys dumb question
Old Jul 16, 2005 | 12:29 PM
Jim D's Avatar
Jim D
Default underdrive pulleys dumb question
What exactly are underdrive pulleys, and what fuction do they serve, thanks Jim.
Old Jul 16, 2005 | 12:40 PM
TheDVS1's Avatar
TheDVS1
Essentially an underdrive pulley slows down the accessory it's driving, thus using less hp to drive it. You gain a few ponies, but you also risk running hotter and generating less voltage, etc. The pulley will be larger than the stock pulley, thus turning the accessory more slowly.
Old Jul 16, 2005 | 01:38 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Not worth the $$ and the heat it causes, IMHO
Old Jul 16, 2005 | 01:42 PM
loudsam's Avatar
loudsam
I agree except for the risk part. I have 0 issues with mine. The only time it's worthwhile to consider it, is when you are doing a cam install. Then it' is no more work, hardly, cause you have to remove the original anyway. Just my .02!
Old Jul 16, 2005 | 01:49 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
with the right tune I don't think are any issues with the UDP. I would agree though do not change it unless you are doing a cam install.
Old Jul 16, 2005 | 11:32 PM
SpeedyZ's Avatar
SpeedyZ
The "underdrive pulleys" you read about on the forum is nothing more than a smaller crank pulley. Like TheDVS1 stated they reduce the speed of the of the accessories by some percent. The slower the accessories turn, the less HP they will use. I stayed away from them becasue I worry about low speeds running like idling around town.
Actually a under drive crank pulley is smaller to turn the accessories slower. Being the crank is the driving pulley then making it smaller will slow the accessories. If you were changing all the other pulleys (all the driven pulleys) then they would need to be larger to slow the accessories.
Old Jul 17, 2005 | 12:11 AM
TheDVS1's Avatar
TheDVS1
That's very true, SpeedyZ. I was thinking about changing the pulley on the accessory, but the proper way to do it would be to change the pulley at the crank, which indeed would have to be smaller. Thanks for elaborating.
To underdrive pulleys dumb question
