DIC code#P0430 TWC System Low Efficiency Bank 2
Old Jul 16, 2005 | 06:31 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default DIC code#P0430 TWC System Low Efficiency Bank 2
Can someone spell this out for me in english please
What do I need to look at here?
TIA
Old Jul 17, 2005 | 12:42 AM
flynbya2's Avatar
flynbya2
Anyone?
Old Jul 17, 2005 | 02:38 AM
loudsam's Avatar
loudsam
I have longtube headers and hi-flow cats and I was getting the same code/s. I did a search on the forum and then determined that I should probably try 02 sims. I did, and I haven't been getting the codes since. I have gotten a code P1154 at least once maybe twice, but haven't lately. Don't know if the sims will help in your case, but they might.
Old Jul 17, 2005 | 12:44 PM
flynbya2's Avatar
flynbya2
Thanks LoudSam!,
I guess I should have also asked,cause I am not sure,which side is bank2? ..Passenger or driver?
Can I cause engine or other damage by driving with this condition??
Old Jul 17, 2005 | 06:55 PM
loudsam's Avatar
loudsam
No, as far as what I've read, and what LPE tells me, these codes P0430/P0420 are not indicative of problems that would affect the safety or well-being of your engine, only a PITA as far as resetting the DIC goes. I would like to add that LPE didn't install my headers/cats and said that I might have this problem with the headers/cats I installed. Irregardless, after the 02 sims I don't get that code/s, but I have gotten P1154 a couple of times, not often. I would also say that the bank 2 is probably the passenger side, but, not sure! I've have gotten quite good at resetting the DIC "on-the-fly" and feel quite lucky that it is that simple to "check engine"!!!
Old Jul 17, 2005 | 07:20 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
http://forums.corvetteforum.com/show....php?t=1097094
P0430 would indicate the right (pass) side.
To DIC code#P0430 TWC System Low Efficiency Bank 2
