My 98 with A4 needed it, due to some FI contamination at 34k miles.
I bought the filter for $11 and the quick-disconnect tools for $15.
I was able to do it on jack-stands. After I figured out just what the hell the quick connect fittings were supposed to do, and after I found the tool that I dropped while fumbling around under there, it only took a few minutes. Overall, it was an hour of time spent for 5 minutes of work.
I did my 01 Suburban right before and it was simple as pie - no special tools required.
Pics? I don't think I could have even shot clear pix given how tight things were in there. Removing the left muffler would have made a lot more room, but that would be too easy.
You don't need to wait until it's empty. The only fuel that spills out is the little bit in the lines and filter - probably a couple ounces I'd guess.
Don't feel bad, it took me 2-1/2 days to install my new GM Bra?
