Air Bridge Help
Old Jul 17, 2005 | 08:52 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Air Bridge Help
I picked up a Carbon Fiber air bridge from an 02 owner and it looks like I'm going to need to drill it so I can plug in the sensor from the air flow unit.(this is a 98) Has anyone ever drilled carbon fiber? I'd appreciate any advice or help as drilling this thing makes me nervous.
Old Jul 17, 2005 | 09:11 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
use masking tape over the area you are going to drill. This will help prevent fraying at the drill site.
Old Jul 17, 2005 | 09:19 AM
Mark 84ltblu
Curise-In V Veteran
Thanks!
Old Jul 17, 2005 | 10:58 AM
sailohio's Avatar
sailohio
And drill slowly letting the bit do the work.
Old Jul 17, 2005 | 11:32 AM
LeMansBlue04's Avatar
LeMansBlue04
I don't know if you are interested but there appears to be a way to convert your older setup to a 5 pin like the 2001 and up setup. This gets the sensor into the MAF.
I have a 2004 so I have never done this but someone has and he documented it here.
http://www.ls1howto.com/index.php?article=25
To Air Bridge Help
