First time it stayed engaged after motor started, and was running, I didn't know what the noise was. After looking under the hood I turned of the key, noise continued. I turned the key back to ON position (not Start) and the motor started up again. Though it must be dieseling.
Turned key off and pulled it out, noise continued. Turned key to ON position (not Start) and motor started up again. I tried giving it a little quick pump on the gas peddle,loud POP noise, and other sound gone.
Drove it for two days , no problem.
Today it did it again and I now know it is the starter staying engaged after the motor starts. Tried disconnecting battery, but each time the starter would continue when battery reconnected, even with the key out of ignition.
Well, the course of events ended up the same as the first time, after running for a minute or two a quick hit on the gas peddle finally disengaged it.
It is home in the garage. So, what am I looking for? Any help?
This happened to me once on my old Firebird. Turned out the solenoid was shorted-out and kept juicing the starter. Try dropping the starter and replacing the solenoid. Make sure all your connections are in good shape too.
In looking things over last night it looks like the power cable has been hot enough to weaken the solder joint on the end fitting attached to the starter.
I don't think this is going to be an easy fix in the end.
Followed the cable from the starter up to the battery.
Found the post melted out of the battery (new red top).
Checking for acid leak under the battery now(hope not).
Dropping exhaust for access.
Dale
Sounds like you're drawing so much juice thru the cable with the shorted solenoid that it's overheated and self-destructed! Solenoids are cheap. Change the solenoid, cable and - battery, if necessary.
Bummer.
Thats exactly what happened, a couple years ago I had a starter stick on a forklift and after about 20 minutes the positive cable to the starter was glowing red and we had to cut the ground cable to kill it.
Starter out on the bench, it is completely FRIED!
Starter gear jammed on end of staft, no spring etc.
Little pieces falling out of it on the bench.
New starter, Optima and cables.
Starts just like it should.
A simple starter failure.
Now that I know how close to a car fire it must have been a wrench to disconnect the battery is a must. The 'crank' fuse # 14 takes too long to access under the passenger floor board.
Glad this went down at home and not on our road trip the South Dakota!
When this happened on my old MSD ignition-equipped Pontiac about 15 years ago, I made the mistake of pulling the coil wire on the distributor to "kill it". Almost killed myself instead. I got the wire partially out of the cap and then the ZAP began. I was leaning against the fender and I could feel the voltage surging thru my legs, arm and hand. I was totally paralyzed with that wire half-out of the cap until the engine fortuitously decided to shut down. I stumbled around rather dazed for a couple of minutes and then was fine. Would've made great video!
ZRON, glad you got everything fixed. Most likely the solenoid fried your starter too, in addition to the cable and battery.
OH, BTW I now have a nice battery disconnect on the Firebird. Cheap insurance.
