HELP Need Part #
Old Jul 18, 2005 | 11:49 AM
CarsRFun's Avatar
CarsRFun
Default HELP Need Part #
just installed Ls6 intake on the back there are 3 connections brake booster hose.. sensor and a small vaccum hose.. the small vaccum hose connects to the intake via a 90degree rubber boot.. during install it fell off and I am unable to find it... I need another one.
HELP
Old Jul 18, 2005 | 12:07 PM
kromberg's Avatar
kromberg
If you can not find the boot, make sure it did not fall into any of the rear intake ports of the heads!!!!
Keith
Old Jul 18, 2005 | 12:25 PM
CarsRFun's Avatar
CarsRFun
I checked vacumed all the ports just to make sure nothing fell in.
Old Jul 18, 2005 | 12:34 PM
AWW2BAD's Avatar
AWW2BAD
Cannot buy the 90 degree boot from GM. comes with a new vacum line. You may want to check a auto parts store and see if they have vacum connectors that will fit that line.
Old Jul 18, 2005 | 12:49 PM
kromberg's Avatar
kromberg
I have an extra one. PM me your address and I will mail it to you.
Keith
Old Jul 25, 2005 | 11:04 AM
CarsRFun's Avatar
CarsRFun
Keith was unable to locate his.. does anyone have the part# for the complete vacum line
Old Jul 26, 2005 | 07:54 AM
CarsRFun's Avatar
CarsRFun
TTT this sucks anyone know???
Old Jul 27, 2005 | 03:15 PM
CarsRFun's Avatar
CarsRFun
TTT still need the part #
emailed Gene, GMpartdirect, Called Ecklers .. No one able to help yet..
Old Jul 27, 2005 | 07:02 PM
LoneStarFRC's Avatar
LoneStarFRC
Check with your local auto parts store. I've seen small nylon vacuum line repair kits offered in the Motormite ("HELP") line. Seems like it was on a purple colored blister-pak card. It includes a small amount of black nylon line and one or two rubber splices. In the same area, I think I saw some of the rubber spices available seperately. Some may be straight and some may be 90 degree type.
BTW, it would be a good idea to extend this line about 3 or 4 inches anyway. If/when I ever have my manifold off again, I'm going to do this. That way you can re-attach the vacuum line first and still have a little slack while you position the manifold back into position. Less chance of accidently pulling the line off after the manifold is in place. HTH
Old Jul 27, 2005 | 07:12 PM
LoneStarFRC
I just checked their web-site and the Dorman part number looks to be a 47409 for just the 90 degree 1/8"x1/8" rubber elbow. (Dorman and Motormite are both part of the same company) HTH
To HELP Need Part #
