Problem with A/C unit\HVAC: Intermittent no power
I contacted the guy on ebay that fixes these units for like $50 but he doesn’t think he can fix this problem. He says it sounds like a grounding\power issue. Which I agree. Unless you guys have another idea of what it can be.
Also, where is the grounding point for the A/C\HVAC unit?
No one any any ideas???
G202 bottom of A-pillar, rt, bolted at the bottom (with SP202)
G202: Splice pack SP202:
Passenger door module (pdm)
Door latch, passenger side
Body control module (bcm)
HVAC control module
IP compartment lamp
Footwell courtesy lamp, right
Vanity mirror lamp, left
Vanity mirror lamp, right
Inside rearview mirror
Bose relay 45
Ignition switch
Blower motor relay c60
Blower motor control processor
Hood ajar switch
Cigar lighter
A/t shift lock control solenoid
I haven't been able to take a look at it on my car yet. But if you have ever suffered from the wet passenger floor before, like I have, that might have corroded the ground connection a little.
I'm going to look at it as soon as the temp goes down a little here. I don't have a garage and hate working on the inside of the car in 100 degree weather.
Let me know if I can help...
VMI07
