Cam help needed...
Old Jul 18, 2005 | 11:43 PM
sting66cp's Avatar
sting66cp
Default Cam help needed...
I am seriously considering new AFR heads for my 01 LS1. I want to change the cam also, who can tell me what the factory cam specs are for this engine. What cam grinds are you running with these heads and how happy are you with your choices? Did you lose much driveability?
Old Jul 19, 2005 | 01:08 AM
lloaf's Avatar
lloaf
220/224--114 LSA Comp Cam, with AFR 205s. Only other changes from stock were GHL Bullets , Blackwing and tune. Made 395 rwhp. Very pleased. Car is totally driveable ,and if you didn't know what a stock c5 sounded like at idle, you might think it was stock. Should also pass CA smog.
Old Jul 19, 2005 | 04:48 AM
Mitch C's Avatar
Mitch C
AFR recommends a 224/228 grind that works very well with 205s. Give AFR a call and they can fill you in about this cam.
Old Jul 19, 2005 | 05:19 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I have a G5X3 cam for sale if you might be interested.
Here's the link: http://forums.corvetteforum.com/show...39&forum_id=53
Old Jul 19, 2005 | 10:05 AM
Silver98's Avatar
Silver98
Factory cam specs, from the book:Chevy LS1/LS6 Performance
Part# 12561721
Valve Lift, inches, Exh/In: .479/.467
Duration Exh/In: 207/196
Lobe Separtion Angle (degrees): 116
Timing: 117/115
To Cam help needed...
