Dallas Area Engine Shops?
Old Jul 19, 2005 | 12:12 AM
diyguy's Avatar
diyguy
Default Dallas Area Engine Shops?
Anyone know someone in the Dallas area that's pretty good with engine/heads AND reasonable on costs? Or any DIY'ers want to take a shot and help?
I could do the work, but it's just to dang hot to be diving in the engine compartment, pulling parts off to get to the top end and check for damage to push rods, springs, seals, seats and valve train integrity -a result I might add from stupidly letting someone drive my MN6 , who accidently attempting power shifting from 2nd back to first instead of third. Big time over-rev, off the scale - now makes smoke - the bluish kind
Spent about an hour pulling plugs and called it quits for the night. Was going to do compression check - ran out of energy, banged up knuckles, sweat burning my eyes. Would rather spend the $$$ and be SURE of the results of checking out the top end.
Has to be a helper/hands on sort of place/person - no way for the "insurance won't let you back in the shop"
My place or yours. Tools, air, and cold whatever you want.
Old Jul 19, 2005 | 06:23 AM
Dark-Knight's Avatar
Dark-Knight
Call Andy or Pat over at 21st Cent MC they can suggest someone.
Old Jul 19, 2005 | 08:47 AM
mcintex's Avatar
mcintex
St. Jude Donor '06-'07
Default Suggestion
You might try posting this request in the Southwest section. I know some of the people hanging out there and they might offer some help. I am a backyard mechanic myself (suspension, tuneup, etc.), but definitely not capable of a motor swap myself. (Yet.)
Also, I have heard great things about 21MC.
Old Jul 19, 2005 | 08:54 AM
MisterC's Avatar
MisterC
Corvette Corner on Main Stret in Rowlett. He's the only one that even touches most of my Corvette friends' cars. Rich also does quality restorations.
Old Jul 19, 2005 | 10:55 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
start with a leakdown and then you should have a gameplan.
Somtimes it is cheaper to get a used ls6 from 21st he allways has a few with low miles.
Old Jul 19, 2005 | 12:29 PM
Jeff Jeff's Avatar
Jeff Jeff
I highly suggest taking it to LG Motorsports. They are a top notch shop. I had a 6 month clutch balance ordeal caused by another "reputable" shop. After a complete tear down they told me "normal for aluminum flywheel".
I took it to LG. They tore it down and identified the problem within 2 hours. It has been perfect since. They build and race vettes, not just work on them like most shops.
Old Jul 19, 2005 | 02:31 PM
stangin4lyfe's Avatar
stangin4lyfe
Take it to 21st Century Musclecar.
I had a local shop(probably the same shop Jeff Jeff is referring to) install a cam incorrectly and refused to fix the problem in a timely manner(5+ weeks without my car!).
In the end, 21st repaired all of the errors from the first install and added LT's, vararam, and a tune(took 21st 2 days).
Old Jul 21, 2005 | 04:53 PM
towercontroller's Avatar
towercontroller
21mc.
To Dallas Area Engine Shops?
