Alternator Help!
You need to have your original alternator rebuilt, you can not buy a NEW alternator for your car because they do not make them anymore... the PCM tells the alternator what to do and when to do it... it is not your average everyday alternator... A New GM alternator and a New PCM flash from the dealer may finally correct this problem.
here is a little tutorial I made a few years ago for this situation to explain how a C5 alternator works. Note, the alternator has to be year specific.
The PCM monitors the alternator through the red and grey wires
The L-terminal circuit from the generator is a discrete circuit (a discrete circuit has no splices and only one source and destination) into the PCM. The PCM applies ignition voltage to the generator L-terminal circuit. A small amount of current flows from this circuit through the generator windings to ground to create a magnetic field which starts the generator process. When the generator is at operating speed and producing voltage, a solid state switch for the L-terminal circuit in the generator opens and the PCM detects that the initial startup current flow has stopped.
The PCM expects to detect low voltage on the L-terminal circuit prior to the generator rotating at operating speed and conversely expects the circuit to be at ignition voltage potential when the generator is operational. When the PCM detects a fault (circuit shorted to ground, or circuit shorted to voltage), the Driver Information Center will display Charging System Fault.
The generator has an input to the PCM called the F Terminal to indicate the percentage of total capacity that the generator is producing. This signal is detected by the PCM as a duty cycle from the generator and displayed on the scan tool as a percentage. The PCM can monitor the generators output under all conditions to determine if it is functioning normally.
When there is low demand from the electrical system on the generator, a low duty cycle percentage will be displayed. As more accessory load is placed on the generator, the duty cycle output detected by the PCM will approach 100 percent. A normally functioning generating system will never reach 100 percent as indicated on the scan tool.
The L and F terminals are the red and grey
Your local Parts house will see any GM 5.7 alternator and think its the same one..but it is not...
Your car requires a French Made Valeo 110 amp alternator, not a Mexican made Valeo 130 amp alternator. The PCM will not recognize it.
