New tires and Active traction problems.
Old Jul 22, 2005 | 08:16 PM
strakap's Avatar
strakap
2nd Gear
Default New tires and Active traction problems.
Just replaced the Goodyear EMT's with Pirelli P Zeros on my 2001 coupe. The front are the original size (245/45-17) but I ended up putting 285/30-18 on the rear (I did not want to go with the smaller diameter tire but they were a good deal).
Took it for a test drive and when I get to 45 mph the active traction handling comes on and will not let me accelerate and further. I am having to drive with the active traction off.
I think the problem is with the new tire size. The rear wheels are making more turns at a given speed since their diameter is smaller then OE. Can I reset the computer so it won't think I am loosing traction?
Thank you for any thoughts on the matter.
Paul
Old Jul 22, 2005 | 09:34 PM
blkvett01's Avatar
blkvett01
wrong side wall hight you have to reprogram the your computer for the side wall hight. I did it my self, went back to a taller tire on the back. The computer has to see a one inch from front to back tires.
Good luck
Old Jul 22, 2005 | 11:42 PM
shurite44's Avatar
shurite44
Paul
The problem is your overall diameter of your rear tire is .95" shorter than your front tire. As long as you are the same height or have a taller tire in the rear you will be ok with AH/TC. Many run identical size tires on front and rear with no problems. My last set was 1/2 inch taller in rear and I had no problems. Here is a tire calculator so you can check your tire sizes.
http://discounttire.com/dtcs/infoTireMath.dos
Old Jul 22, 2005 | 11:51 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
You bought the wrong tires for the rear...
VR
Old Jul 23, 2005 | 12:57 AM
Bill Dearborn's Avatar
Bill Dearborn
You can't reprogram the ABS/TC/AH computer. It is separate from the PCM. You are getting both brake activation on the rear brakes and reduced throttle. If you coast down a hill in nuetral fast enough the rear brakes will activate to keep the wheels from spinning. You need to get larger rear diameter tires or swap the fronts and rears. Run the 18s on the front and the 17s on the rear.
Bill
Old Jul 23, 2005 | 08:41 AM
strakap's Avatar
strakap
2nd Gear
Thanks for all the help. Any other suggestions?
Paul
Old Jul 23, 2005 | 09:50 AM
shurite44's Avatar
shurite44
You could sell either the front or rear tires here on the forum and replace with an appropriate size. You will lose a little money but you really can not run like that. Unless of course you switch front and rear like the one member suggested.
Old Jul 23, 2005 | 02:58 PM
bbvett's Avatar
bbvett
I remember the Predator tuner enabled tire size ajustment. Expensive fix.
Old Jul 23, 2005 | 04:36 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
That only is for speedometer calibration. It does not affect the TC module.
Either switch to proper height tires, or learn to live w/o traction control and active handling...those are the only two options.
Old Jul 23, 2005 | 05:53 PM
shurite44's Avatar
shurite44
That is your only option.
Old Jul 30, 2005 | 06:21 AM
GTENIT's Avatar
GTENIT
I Am Having The Same Problem The Rear Tires Are One Tenth Smaller In Diameter. Comes Up Traction Control Active Then Nothing And Turn Control Off Just Fine. When Shut Car Off It Is Fine Untill Get To Highway Speed. Havent Looked To See If It Starts At 40 Or Just Above.
Old Jul 30, 2005 | 07:25 AM
vetterdstr's Avatar
vetterdstr
Maybe it would be best if a blanket statement was made... the front tires are supposed to be 1" smaller outside diameter than the rears..... Now some C5's can run with them close to the same size... and one wont know that until they try it. NONE of them can run with the rear tire smaller (outside diameter) than the front.
So go out and buy the correct tires for the car this time. If you have any questions of what tire combinations will work, please feel free to ask.
VR
To New tires and Active traction problems.
